Kalkveien Posted April 4, 2017 Report Posted April 4, 2017 (edited) Hi. Is it possible to remove the oil pan on a KE20 3K whitout lifting the engine or lower the front end? Any tips? Edited April 4, 2017 by Kalkveien Quote
7000rpm Posted April 26, 2017 Report Posted April 26, 2017 I just had to do this on a ke70. loosened engine mount nuts, jacked up the engine from the gearbox bellhousing and moved the sway bar out of the way. Had to twist the pan sideways to clear the oil pick up Quote
