KaboomJohn111 Posted January 22, 2017 Report Posted January 22, 2017 Hey all quick questions, All are referring to 1983 KE70 corolla Will a T-50 Shiftier assembly or a T-50 shifter (rod only) fit a K-50 box and/or shifter assembly? Will a K-40 Shiftier assembly or a K-40 shifter (rod only) fit a K-50 box and/or shifter assembly? Got a K-50 box but shifter feels sloppy, tried finding rebuild kits and all they have a T-50 shifter rebuild kits or entire T-50 shifter assemblies and I have a spare K-40 shifter assembly and wondered can I swap the shifter rods over (since all parts of the K-40 shifter are in good order) Thanks Guys, Again I'm Strictly referring to KE70, not anything prior Quote
B.L.Z.BUB Posted January 23, 2017 Report Posted January 23, 2017 They're all transferable. A mate is running a t50 short shifter in his ke70 box. As long as they are all from ke70s you'll be fine. Shifters were different in the ke30/55 k boxes. Quote
KaboomJohn111 Posted January 23, 2017 Author Report Posted January 23, 2017 I'm not sure if it is in the FAQ, but every other forum and topic of such I have looked at are either inconclusive, or someone brings up ke30's and ke55's then the topic at hand is lost to the dark ages They're all transferable. A mate is running a t50 short shifter in his ke70 box. As long as they are all from ke70s you'll be fine. Shifters were different in the ke30/55 k boxes. Is it the whole assembly transferable or just the shifter rod (i.e take apart shifter one and put it in to the assembly/mount and pivot of the other) If anyone can add photo's this would help this topic more and clear confusion (hence why I made this topic because every other was inconclusive) Quote
LittleRedSpirit Posted January 23, 2017 Report Posted January 23, 2017 http://partsfan.com/toyota/gr/pnodetail/724d0cb881391f6cf7e0198aec508f24/3357014021/ 1 Quote
LittleRedSpirit Posted January 23, 2017 Report Posted January 23, 2017 http://www.rollaclub.com/board/topic/70723-adapting-t50-shift-lever-to-a-k4050/page__p__690628__hl__+t50%20+k50%20+shifter#entry690628 1 Quote
Mechanical Sympathy Posted January 23, 2017 Report Posted January 23, 2017 Damn that's conclusive. 1 Quote
KaboomJohn111 Posted January 23, 2017 Author Report Posted January 23, 2017 Thanks guys, for the help Quote
