Hi Guys,
I am wondering what type of ignition systems have found to be good for k series engines. I gather many would have nippon denso electronic dizzys, converted from points.
Has anyone tried the Pertronix Australia conversion kit? Or used an MSD system to increase spark and have a rev limiter option?
I'm building a 4k with 11.5:1 compression and twin sideraughts for mostly track racing. Am curious of the electronic ignition options of what has proven to be reliable and perform well
Edited by 7000rpm
I use a denso 5k electronic dizzy with a Streetfire CDI (MSD's budget line) with a Bosch coil and 1.0 gapped plugs.
Capacitive discharge, multi spark to 3000rpm and rev limiter.
More energy that you'll every need.
I'm running a MSD 6-AL with their Blaster2 (i think) coil with a 4k points distributor (because the advance curve was a little better than the 5k one). Basically the same as Gavins but with more spark but for more monies. I probably wouldve gone the streetfire if i hadn't of gotten the 6al for mates rates.
Don't get too excited about MSD rev limiter tho, its more of a safety precaution for run away engines than a limiter to bounce off like the BeeR the silvia boys run.
I found that it was only when i have super heavily modified my motor that i even need to go as far as an MSD.
