Hamtarohachirokoo Posted October 5, 2016 Report Posted October 5, 2016 Can i use that in my 4k block?if can't what should i do to put that crankshaft in my 4k block?? Tq Quote
altezzaclub Posted October 5, 2016 Report Posted October 5, 2016 I don't know, but find it unlikely as the 4K stroke is 73mm, while the 7K is 87. That means it describes a circle 14mm larger in diameter, so take a look inside a 4K and see if there is that distance between the crank and the bottom of the cylinders or the sump. Can it swing past the sides of the block? Of course it also pulls the piston down an extra 14mm, so they drop out the bottom of the block, and it pushes them 14mm further up, into the head. What sort of piston would have a 14mm shorter distance between the gudgeon pin and the top?? There would be no room for the rings. It would be a major re-engineering job, if possible at all. Quote
ke70dave Posted October 5, 2016 Report Posted October 5, 2016 Following on from Altezza, big question is why do you want do it? Quote
Hamtarohachirokoo Posted October 9, 2016 Author Report Posted October 9, 2016 (edited) Owh like ok2 thanks for your opinion...its means i would to use short conrod if i want to use 7k crankshaft to 4k block.thanks bro and i thinks its so many job re engineering i must do.hmm bro can you give me a conrod spec for the k series engine?i want to know length,sizes bearing n pin? Edited October 9, 2016 by Hamtarohachirokoo Quote
altezzaclub Posted October 10, 2016 Report Posted October 10, 2016 I haven't got conrod dimensions, but remember that if a short conrod doesn't hit the head at TDC because it is short, it will pull the pistons even further out of the cyl at BDC. In this picture you can see the 20% increase in stroke, both TDC and BDC in red. The piston skirt sticks out the bottom already, as shown in blue, and it will be 20% further out with the 7K crank. I'm not sure if it will stand that. Also, don't forget your piston speed will be much higher, which is why they increase bore rather than stroke. Quote
tojo2 Posted October 10, 2016 Report Posted October 10, 2016 rod dimentions http://www.spoolimports.com/spool-conrods/toyota (7k = 7afe) Quote
7000rpm Posted October 12, 2016 Report Posted October 12, 2016 On 10/10/2016 at 8:01 PM, tojo2 said: rod dimentions http://www.spoolimports.com/spool-conrods/toyota (7k = 7afe) Far out, those rods would be nice for the 4k I'm building. Quote
joshua.mathews Posted November 16, 2016 Report Posted November 16, 2016 I habe tryed putting the 7k crankshaft into a 4k/5k block it does not work but the time you notch out the bore for cleanance for the conrods Hence why the 7k block is wider and taller Quote
