Hi guys,
Got a '75 ke35 and at the moment the tail lights are out, aswell as the Parker lights and all dash lights.
Any suggestions on fixing this? A few people have said its just a fuse but I can only find 1 fuse box and they are all good?
Any help is appreciated
Thanks
Tail, parker & dash lamps are all fed by a 15A fuse, labelled "TAIL".
If the car runs, and everything else works except these lights, then is more than likely that it is the fuse. Have you tested it with a test lamp, or multimeter, to check that there is 12V on both sides of the fuse to chassis ?
Do the headlights work ?
If you haven't got a test lamp, or meter, then swap Head & Tail fuses, and see if tail lights now work, & head lights don't.
That will prove if it's the fuse or not.
Other than that, it can only be a major wiring open circuit.
Get a wiring diagram on this site & trace it out.
The lighting circuits of all the early model Corollas were pretty much the same.
Cheers Banjo
Edited by Banjo
