I need to run a universal sender in my tank because the stock one doesnt love e85.
Does anyone know, or could please measure the resistance of the stock fuel sender on full and on empty. if i could get this info i could match it to an aftermarket sender.
So if anyone has a ke30 sender lying around they could put a multimeter on ohms to it, or a manual that tells the story. I have a gregorys manual and its not in there. cheers matt
What year is your KE30? I noticed there is a difference in the fuel gauge readings. I put a 1976 KE35 gauge in my KE30 and the fuel gauge was a bit out, so I put in a 1976 fuel sender and it was OK.
Looks like 3.6 Ohms Full and 110 Ohms Empty.
Measured with Ohms meter across body and pole off fuel sender unit.
Bottom most position for empty, top most position for full.
Edited by cuzzo
if u are stills trugling to find this, i can tell you suzuki have a fuel level sender with the exact same setup as the toyota 3-110 ohm sender. Its installed in suzuki multicabs and Toyota liteaces.
