maric1 Posted March 17, 2016 Report Posted March 17, 2016 HI Just bought a s14 alloy radiator to put into my ke30 which has a sr20. whats the best way to go about it to make it fit . do i need to make up custom brackets . any photos or info would be appreciated cheers Quote
It's_AUDM_Yo Posted March 19, 2016 Report Posted March 19, 2016 Put it and so what needs to be done! I assume it would be a case two L brackets with a hole drilled in for lower mounts Bolted or welded to rad support. Top mounts I would get some s13/14/15 ones and if your lucky height wise you could bolt them to the top KE30 S14 radiator is going to be like 150% the size of a KE30 so unless you're cutting metal 1/2 of its will be covered Quote
oh what a nissan feeling! Posted March 20, 2016 Report Posted March 20, 2016 Have a look at my ke25 thread, the same will be required for a ke30 if the height of the rad support is the same. can't link it I'm on a crap phone Quote
maric1 Posted March 20, 2016 Author Report Posted March 20, 2016 cheers guys. ended up using a long plate for bottom and made custom brackets for the top. now just gotta make sure the bottom hose will fit Quote
ke70dave Posted March 20, 2016 Report Posted March 20, 2016 Out of curiosity why did you choose an s14 radiator? As mentioned I reckon will be far too wide for the opening in the ke30 front. Which is basically wasting half the radiator Quote
maric1 Posted March 20, 2016 Author Report Posted March 20, 2016 I'm running a sr20 so wanted to make sure it doesnt get hot. ive seen most people running them with the sr20 conversion Quote
