Hi guys!
I've been looking to replace my master cylinder on my ke10 as it's leaking and it gets stuck sometimes.
Many people say that rx3, rx4, galant and pajero MC would fit.
Could someone link one that would fit as theres always multiple different cylinders available on ebay?
Best option is to get yours rebuilt.. That way everything fits. A lot of people always say stuff fits.. Doesnt mean it does. Also wouldn't be direct fit.
This is a Mazda rx4 cylinder on my 10.
The cylinder bore hole in the firewall needed to be enlarged, the mounting bolt hole on the cylinder
needed to be elongated and new brake lines were made to suit the dual circuit set up.
The pushrod from memory was long enough to get adjustment.
Overall a fairly easy swap and excellent upgrade, I do run a disc brake front though.
