Trev Posted January 5, 2012 Report Posted January 5, 2012 On 1/5/2012 at 1:44 AM, TOMsGPTurbo said: Thanks Trev, well actually I do need to borrow some tools .. :hmm: .. would you have a engine crane lying around ... and maybe a ute lol :lolcry: Nah no crane anymore but yes to the ute. Quote
TOMsGPTurbo Posted January 5, 2012 Author Report Posted January 5, 2012 (edited) Can't get the darn turbo off? Turbo is bolted to manifold, I've unbolted exhaust, unbolted manifold, and she's not moving.... Trev, no worries, I might save up and buy one or rent one, or my other idea is cut the front off and unbolt engine and drop it onto the ground and move it from there somehow... Edited January 5, 2012 by TOMsGPTurbo Quote
TOMsGPTurbo Posted January 5, 2012 Author Report Posted January 5, 2012 Ahhhh manifold has 6 bolts, 4 up top and 2 below... and hitting it with a hammer will not help get it off when the two are still done up. Good news nearly have all parts needed to start the 2012 rebuild now how do i take wind screen off??? Quote
carbonboy Posted January 5, 2012 Report Posted January 5, 2012 (edited) On 1/5/2012 at 3:45 AM, TOMsGPTurbo said: Loaded nearly all the parts into the car, time for a drop off o home and hide them from my wife so I don't get in trouble lol :P hmmm cut the bottom out of a box and stick it over the parts and hope she never looks inside or moves it ... :hmm: ^^^ :lolcry: Shame to hear about things not quite going your way, I know the feeling. :( Maybe giving it a gentle tap with a hammer & a block of wood to loosen it? Edit: On 1/5/2012 at 11:22 AM, TOMsGPTurbo said: Ahhhh manifold has 6 bolts, 4 up top and 2 below... and hitting it with a hammer will not help get it off when the two are still done up. Good news nearly have all parts needed to start the 2012 rebuild now how do i take wind screen off??? Okay, so no hammer job, I forget bolts too! :lol: Windscreens are a pain, I can recommend LOTS (as you will break lots) of the long, snap-off style blades for a stanley knife to cut through all the sealant from both sides to have some hope of pulling it out without breaking it. Edited January 5, 2012 by carbonboy Quote
TOMsGPTurbo Posted January 5, 2012 Author Report Posted January 5, 2012 On 1/5/2012 at 11:26 AM, carbonboy said: ^^^ :lolcry: Shame to hear about things not quite going your way, I know the feeling. :( Maybe giving it a gentle tap with a hammer & a block of wood to loosen it? Edit: Okay, so no hammer job, I forget bolts too! :lol: Windscreens are a pain, I can recommend LOTS of the long, snap-off style blades for a stanley knife to cut through all the sealant from both sides to have some hope of pulling it out without breaking it. lol I was just going to recline the drivers seats and give it a good kick, just like in the movies when the car is under water.... (the under water part was was plan b) 1 Quote
carbonboy Posted January 5, 2012 Report Posted January 5, 2012 Definitely keep the water for plan b. :laff: Do you need it intact? Got the feeling too much pressure (the sealant holds them pretty damn well) will cause the screen to crack. :( Quote
TOMsGPTurbo Posted January 7, 2012 Author Report Posted January 7, 2012 Spot the differences 3 things have changed Quote
carbonboy Posted January 7, 2012 Report Posted January 7, 2012 (edited) Strutbrace... It's in a garage... ???... Edited January 7, 2012 by carbonboy Quote
TOMsGPTurbo Posted January 8, 2012 Author Report Posted January 8, 2012 Yes to strut brace ... actually 3 more... Clues kyb no hole air ....... i put in lowered KYB suspension, EP82 Strut brace, pod air filter, replaced side mirror, and did a wheel rotation next ...CT12/9 hybrid turbo, turbo back 3" exhaust, front mount and ditch air con. Quote
Trev Posted January 8, 2012 Report Posted January 8, 2012 On 1/8/2012 at 1:24 PM, TOMsGPTurbo said: Yes to strut brace ... actually 3 more... Clues kyb no hole air ....... i put in lowered KYB suspension, EP82 Strut brace, pod air filter, replaced side mirror, and did a wheel rotation next ...CT12/9 hybrid turbo, turbo back 3" exhaust, front mount and ditch air con. You get a new pod? I didn't even notice the wheel, I looked and thought 'hmm wheels are the same' Will have to get the hub off the other car and get it onto this one or get another wheel stud. Just let me know when you need me over there. Quote
TOMsGPTurbo Posted January 9, 2012 Author Report Posted January 9, 2012 (edited) Thanks Trev, hopefully this darn heat goes away... and hopefully this heat goes back to the 24ish degrees ... Pod is the one i found in the box.. not new but on the car ;) Edited January 10, 2012 by TOMsGPTurbo Quote
TOMsGPTurbo Posted January 10, 2012 Author Report Posted January 10, 2012 (edited) I really have to get my arse in gear and the interweb connected at my new place, also motivation is down at the moment :( Things to do Swap intake manifold Disconnect and remove aircon Start selling parts to save up for coilovers and rego if anyone out there in interweb land requires a part for their el31/ep70/71/82/92 that i might have lying around lemme know... Edited January 10, 2012 by TOMsGPTurbo Quote
Subaru_kid Posted January 13, 2012 Report Posted January 13, 2012 On 1/10/2012 at 11:36 AM, TOMsGPTurbo said: I really have to get my arse in gear and the interweb connected at my new place, also motivation is down at the moment :( Things to do Swap intake manifold Disconnect and remove aircon Start selling parts to save up for coilovers and rego if anyone out there in interweb land requires a part for their el31/ep70/71/82/92 that i might have lying around lemme know... Aww cmon man! You don't have much more to do, most of it is behind you! You can do it!! Car looks awesome :) just needs new shoes and coilies... itll all come together in time ;) Quote
TOMsGPTurbo Posted January 17, 2012 Author Report Posted January 17, 2012 Hope to have a big update soon, taking heaps of pics of progress and learning a little on the way, lets just say I've been cutting the car up... Quote
Trev Posted January 17, 2012 Report Posted January 17, 2012 On 1/17/2012 at 8:44 AM, TOMsGPTurbo said: Hope to have a big update soon, taking heaps of pics of progress and learning a little on the way, lets just say I've been cutting the car up... I hope the car is the only thing that gets cut :lolcry: Quote
