Hi guys, need a bit of knowledge about brake masters. I'm using the standard pb r brake booster and master but when installed the pressure switch sensor and bleed nipple hit the intake mani. I've been to abs and they've said that there are no aftermarket masters which will fit a standard booster. What are you guys using?? Is a ke30 booster/master narrower? Cheers, Jason
Edited by JasonKE55
I believe ohwhatanissanfeeling is using a Commodore master on a 55 booster with his sr. Have a look in his projects thread, I was asking about it late last year.
  • Upvote 1
