Hi guys probably been asked a thousand times, are the standard fuel lines in the ke30 large enough to run surge tank or am I better off running a new feed and using the existing as a return line? Cheers
Recommended minimum for 4AGE is 8mm feed and 6.3mm return
I went with 10mm feed (Aeroflow stainless steel braided hose) and used the 6.3mm steel return (the original feed line)
Got all my fuel gear (hose, attachments , surge tank, pump etc..) from Rocket Industries - good quality gear and good guys.
Edited by dandison
