Hey fellas,
Another question about me old conversion. Trying to figure out the best way to run a clutch cable to my sr trans. Would you guys suggest buying standard clutch cable and modifying or any other ideas from the guys who have done it before??
Cheers
You'll need to convert your clutch pedal to operate hydraulically.
I'm using a TA22 clutch master as it bolts onto existing KE55 firewall holes without major modifications (you need to drill a hole in the clutch pedal for the master cylinder plunger), but others (silvia?) may also be suitable.
Edited by Mechanical Sympathy
