GJM85 Posted September 26, 2015 Report Posted September 26, 2015 (edited) I'm going to turn out a few sets of these brass rocker spacers for the trusty K series. They're a straight swap for the springs and will stop your rockers from floating off the valve at high engine speed. Cost to you estimating $20-$50+ pst depending on numbers and and my costs. Any interested? Edited October 1, 2015 by GJM85 1 Quote
Taz_Rx Posted September 26, 2015 Report Posted September 26, 2015 You know I'm down for a set mate. Quote
GJM85 Posted September 26, 2015 Author Report Posted September 26, 2015 I'll still make you a set if no ones interest Taz. Quote
kickn5k Posted September 27, 2015 Report Posted September 27, 2015 (edited) I'll grab a set or two. Edited September 27, 2015 by kickn5k Quote
TOMMYS Ke 11 Posted September 28, 2015 Report Posted September 28, 2015 At that price Gavin you are going to be a very busy man :thumbsup: very Cheap :yes: . Cheers:- Stuart :wave: Quote
Feral4K Posted September 29, 2015 Report Posted September 29, 2015 Just a quick question will the spacers have any natural float at all to them?,As I'm a little concerned about excessive wear in the one spot of the valve head is all? Cheers dad... Quote
GJM85 Posted September 29, 2015 Author Report Posted September 29, 2015 (edited) The spacers that are in my engine have about .5mm (.020") hot clearance total between one rocker and the spacer when the corresponding pair are off load. That clearance reduces as the rockers come under load but the spacer can still rotate. I personally thought I made that lateral clearance to large so I intend to reduce that clearance to 0.2mm (.008") which will reduce the rockers lateral movement off load. But possible to much...? The shaft I measured at 15.8mm or 5/8 of an inch and the spacer bore is 16mm which allows oil clearance and clean fitment over the shaft. Edited September 29, 2015 by GJM85 1 Quote
GJM85 Posted September 29, 2015 Author Report Posted September 29, 2015 I've sourced the brass and will pick it up tomorrow along with a few other bits to make the job bit easier. Production will likely start on Thursday and I plan to have the first 10 sets produced by the end of the weekend. I'm offering these first sets to Rollaclub.com forum users exclusively. Cost will be 55 gold coins posted. 1 Quote
parrot Posted September 29, 2015 Report Posted September 29, 2015 Bargain. Thanks for going to the effort! Quote
