Hi Guys,
The clutch fork rubber boot is different on the 4 speed & 5 speed bell housings.
The rectangular hole in the 4 speed gboxes are approx. 60mm x 30mm, whereas the 5 speed boxes, the same hole is approx. 70mm x 40mm.
The smaller rubber boot for the 4 speed boxes is commonly available on line from a number of sources, but I am finding it hard to find the part number, or a source for the larger one, to fit a 5 speed gbox.
Anyone know the Toyota P/N or a local source ?
Cheers Banjo
Toyodiy lists part numbers to suit a KE55 hardtop 5 speed
31126-10030 (06/1976 - 02/1979)
31126-12040 (03/1979 - 06/1981)
Amayama lists both as "upon availability", though Phils Rotarys list their "KE70 fork release rubber" as part number 31126-12040 so that may well suit a 5 speed.
http://www.ebay.com....=item1e9e906b22
I went out one day last year and purchased one to suit a 4 speed and Phil did ask me at the time if it was for a 4 or 5 speed - so I assumed he has both!
Edited by Mechanical Sympathy
