mitch4397 Posted June 25, 2015 Report Posted June 25, 2015 (edited) Hey folks, After some advice on thermo switch location for a ke20. Is it possible to not mount it in the engine bay, and attach it to one of the heater houses in the interior using a similar fitting in this pic? Being further away from the radiator would it require a lower "on" temp? Mitch Edited June 25, 2015 by mitch4397 Quote
parrot Posted June 25, 2015 Report Posted June 25, 2015 What happens when you turn the heater off? Quote
ke70dave Posted June 25, 2015 Report Posted June 25, 2015 You can mount it there, bad idea though as parrot suggests. Quote
B.L.Z.BUB Posted June 26, 2015 Report Posted June 26, 2015 I use one of these http://pages.ebay.com/link/?nav=item.view&id=190998540483&alt=web Quote
parrot Posted June 26, 2015 Report Posted June 26, 2015 Another cheap option if the size works, is to grab a top thermostat housing off something 80's onward at the wreckers with a built in temperature switch to trigger fans. I've got an AE82 top on a AE86 bottom on my 4AGE. I remember at the time looking at Camry's and what not, and there was some variation in size and angles. If one fits on K housing, very cheap, and almost factory. Quote
mitch4397 Posted June 26, 2015 Author Report Posted June 26, 2015 (edited) cheers for the responses, Had a sus of the digital temp controls, interesting but probably not what I'm after. So scrapping the heater hose idea, hows about this handy little nipple coming off the water pump that was otherwise going to be plugged...? Edited June 26, 2015 by mitch4397 Quote
tojo2 Posted June 26, 2015 Report Posted June 26, 2015 thermostat wateroutlet for K series with threads for fan switch 16333-12011 ke70, kp6# and late ke3# had them here. If toyota don't have them , amayama got them listed. Quote
ollienewc Posted June 27, 2015 Report Posted June 27, 2015 That's a real nice looking engine bay you've got there mate :y: Had a look back at your thread, such a sweet twenty. Would love to see some updates Quote
parrot Posted June 28, 2015 Report Posted June 28, 2015 Whatever setup you use has to have access to coolant within the circulating cooling system on the radiator side of the thermostat at all times. The outlet Tor has listed would be the easiest and most reliable way of doing it. At $57.50 plus post, you would be hard pressed to find a cheaper option also. Quote
mitch4397 Posted June 29, 2015 Author Report Posted June 29, 2015 ended up going the davies craig thermo switch kit. ollie, might do soon. Quote
5KKid Posted June 29, 2015 Report Posted June 29, 2015 looking good reminds me how mine started, I have been running a Davis Craig and VS Commodore fan teck screwed into the fan shroud "fits perfect" setup for 20 years on mine and it's still going strong, I wonder if the digital controllers would go the distance, cheap enough though, keep up the good work Quote
