funwithsmexy Posted May 29, 2015 Report Posted May 29, 2015 Hey, I've just picked up my 2nd ke70 and this one is unregistered but doesn't need much. My indicators when I turn them left or right it puts on hazard lights is this a wiring issue or be a globe issue. They do flash the lights so I'm guessing a wiring issue (ground/fuse/connection issue) any help would be awesome ill share some photos soon its flat front too. c: Quote
altezzaclub Posted May 30, 2015 Report Posted May 30, 2015 Sounds like wiring, so just start at the bulbs and test each wire, then work your way back to the indicator switch, which is where I reckon the problem will be. Quote
