Hello there
I am in the progress of installing the rear axle of a ae86 and the technotoytuning brake kit in the front.
But i am wondering if the brake master cylinder and booster will be enough for the brakes.
Anyone can help me this? And knows what cylinder i will have to use. :)
Thanks
Your best bet is to compare piston sizes.
Find out the following info:
Original front and rear brake piston area (remember drums have 2 pistons)
Proposed new front and rear brake piston area.
Then you can compare.
