Hi all,
today i noticed something odd. my right indicator light would half light up when i braked and that with the headlights on sometimes the indicator would stick or be unresponsive. I have so far figured it has to do with my steering column. it was also messing with the right hand brake light.
Has anyone had this happen before?
Does anyone know what it might be?
How can I fix it?
Conah.
Bad earth???
I'd expect so- Check all the bulbs in the indicators, side lights and brake lights. Look for broken wires, corroded wires and bulbs, and twin-filament bulbs put in backwards.
Then pull the steering wheel & indicator stalk off and solve the sticky indicator problem. I don't think it will be related to the brake light problem.
Here's the KE70 circuit, it must be similar.
