Killar_of_giants Posted February 14, 2015 Report Posted February 14, 2015 KE30. Does anyone know of a decent suspension specialist on the Southside of Brisbane? After taking it to 2 differant places for allignment, my car handles worse then it was before. Quote
LittleRedSpirit Posted February 14, 2015 Report Posted February 14, 2015 Brian at Rocklea mechanical mate. Quote
B.L.Z.BUB Posted February 14, 2015 Report Posted February 14, 2015 Andrew at Southside Suspension, he's a Rolla guy too. Quote
Killar_of_giants Posted February 14, 2015 Author Report Posted February 14, 2015 Thanks, Ill give them a call. Quote
CREEDY Posted February 15, 2015 Report Posted February 15, 2015 Most places will only adjust toe for wheel alignment. ke series usually have adjustable caster too. try a place with a laser sight wheel alignment machine (hunter, visualiner, hoffman etc) i found the older ones i used weren't hugely accurate. Quote
Killar_of_giants Posted February 15, 2015 Author Report Posted February 15, 2015 Yeah ive modified the front end so I need someone to 'tune' it. Theres only caster and toe. The only thing thats been done to caster is the last shop adjusted the drivers side to compensate for road slope. They over shot the mark which ive sinse corrected. I can't see how the caster isnt wrong seeing as Ive modified the front and replaced all heavilly worn bush's etc. Ill call Southside Suspension tomorrow as I work down that way. Quote
ke70dave Posted February 15, 2015 Report Posted February 15, 2015 (edited) Go to a place that will give you a before and after report. Also decide on your settings and write them down and give to the guy doing the alignment. Then before you pay compare it to the "after" report.... Edited February 15, 2015 by ke70dave Quote
