Hey just brought myself a ae70 corolla was just after more info on the difference between ae70 and ke70 ie 4age engine swap, changing stud pattern and LSD diff that doesn't require shorting and the best and easy way on lower it cheers for the help any info would be appreciated -😉
Really, the only difference is the T50 gearbox instead of the K50, and the 4A motor instead of the 4K. The T50 needs a hydraulic clutch, so the pedal box becomes different.
Diffs are the same old whiny Borgy, wheels and suspension the same. We've got 3 AE71s and at least 4 KE70s lying around on the farm with bits being swapped between them all the time.
To lower it cut a coil off the front springs and 1.5coils off the rear... or go and buy lower springs. Don't forget that if you change the ride height you will need a wheel alignment afterwards.
