JamesCollins97 Posted December 14, 2014 Report Posted December 14, 2014 I want to lower my ke55 too a tidy height, what's the best way of doing it ? Quote
Taz_Rx Posted December 14, 2014 Report Posted December 14, 2014 ....using the search function ;) Quote
Jono.C Posted December 14, 2014 Report Posted December 14, 2014 What's your idea of best? Best overall? Best for cheap? Best for Motorsport? Depends what you're going to use it for Quote
Dzhoel Posted December 15, 2014 Report Posted December 15, 2014 Chop the springs and add lowering blocks to the leaf springs Source: Quote
coln72 Posted December 15, 2014 Report Posted December 15, 2014 (edited) Chop the springs and add lowering blocks to the leaf springs Source: Chopped spring = illegal That said, I ran them for years with out an issue. Best bet would be to obtain some brand name lowered coils for the front with heavier strut inserts and to get your rear leaves reset with some decent rear shocks. For the rear, look at Commodore wagon shocks or early Monaro rear shocks as both will fit (KE35 anyway) Edited December 15, 2014 by coln72 Quote
Jono.C Posted December 15, 2014 Report Posted December 15, 2014 Technically cut springs aren't illegal, It's the un-captiveness and generally stroke length too short thats illegal. Quote
Super Jamie Posted December 15, 2014 Report Posted December 15, 2014 Yes, cut springs are illegal. It is against light vehicle modification rules to cut or weld any cast or otherwise one-piece suspension component. Quote
Jono.C Posted December 15, 2014 Report Posted December 15, 2014 Got a car past engineering with cut falcons in the front. I'll take the engineers word Quote
coln72 Posted December 15, 2014 Report Posted December 15, 2014 Wouldn't want to be arguing that to the insurance company in the event of an accident. Or in a court of law if there is a fatality...... Quote
snot35 Posted December 15, 2014 Report Posted December 15, 2014 As said, brand name lowering springs for the front, reset leaves and probably some roll center adjusters to keep the geometry all in step. 1 Quote
styler Posted December 17, 2014 Report Posted December 17, 2014 +1 for the above Also remember bigger wheels add height to the car, something to keep in mind when lowering. Quote
