batmo Posted December 11, 2014 Report Posted December 11, 2014 I'm new to modding a KE70 so be gentle. Putting a much higher powered turbo engine in my car and have been told by all the diff will blow asap. Not too keen on swapping to an R31 diff if it's not totally needed and am prepared to address the KE diff if it's viable. The car will be used for circuit with semi slicks so that said, is there any after market to strengthen the diff in my car alredy? Quote
B.L.Z.BUB Posted December 11, 2014 Report Posted December 11, 2014 Apart from welding the Diff locked there's no real other options. No LSD available. I don't even think there are spools available. Your best bet is to find a T series Diff out of a TE72/T18 or a USDM/JDM AE86. Plenty of LSD options, disc brake options and best of all they bolt in. Quote
LittleRedSpirit Posted December 11, 2014 Report Posted December 11, 2014 If he's putting a much higher power engine in with a turbo then he may well need at least a skyline diff or an F series as the torque will smash a T series ae86 diff. I've always wondered if for pure circuit you can nitrite or shot peen (or something else if I'm too ignorant to know what its called) the T diff gears and coat them also to make it hold up to higher torque, run cooler and get away with the bolt in option at the lightest possible weight. Quote
kickn5k Posted December 11, 2014 Report Posted December 11, 2014 On 12/11/2014 at 5:31 AM, LittleRedSpirit said: I've always wondered if for pure circuit you can nitrite or shot peen (or something else if I'm too ignorant to know what its called) the T diff gears and coat them also to make it hold up to higher torque, run cooler and get away with the bolt in option at the lightest possible weight. Cryo treating and isotopic(spelling?) polishing helps a lot. Oil temps are lower and less bearing/steel material contaminating the oil. Quote
altezzaclub Posted December 11, 2014 Report Posted December 11, 2014 The RA40 rally car twisted an axle in the T-series, using the stock 18RG 2litre. That was the welded diff I reckon, it throws a lot more stress on the axles. Both had quite worn splines too. I'd say start with a T-series from a Celcia or similar as it bolts straight in, and if you do break it you at least have time to start preparing something bigger. The F will need mounts welding onto it I think, the Skyline will need shortening and mounts, as will the ultimate, the Hilux. Quote
B.L.Z.BUB Posted December 11, 2014 Report Posted December 11, 2014 Best bet is to let us know what power it needs to handle then we can go from there. Its all speculation if we don't know if its 200HP or 600HP. Quote
batmo Posted December 11, 2014 Author Report Posted December 11, 2014 (edited) 400rwkw boosted 6 through a T56 on methanol is the drive train. It's not a drag car but will give it a run or 2 just because but is a dedicated track car with zero street duties. Really not into failing a diff at the top of 4th with 30psi on board so please be blunt lol Edited December 11, 2014 by batmo Quote
indelible Posted December 11, 2014 Report Posted December 11, 2014 sounds like you need a hilux diff at least which will need to be shortened,+ axles re-splined and mounts welded on to suit your car ect Quote
springersrolla Posted December 11, 2014 Report Posted December 11, 2014 Yeah with that sort of power and setup I wouldnt consider a stock diff. 9" 8 3/4" hilux diff all options Quote
batmo Posted December 11, 2014 Author Report Posted December 11, 2014 So the issue with the stock diff would be axles are weak and gears will strip? Would this be caused by the diff carrier getting all out of alignment under heavy torque and loading up components on bad angles or just out right weakness in a perfect geometry situation (should that ever be able to exist!) A diff housing cradle could be an easy option or just meh, go the hilux or R31 diff? Quote
Taz_Rx Posted December 11, 2014 Report Posted December 11, 2014 An external brace won't do shit, everything is simply too small for that much power. Quote
altezzaclub Posted December 11, 2014 Report Posted December 11, 2014 Quote everything is simply too small for that much power. X2 You're past a Skyline diff too I think. You really need a diff out of a car with similar grunt, or a truck that hauls real weight... Start with a Hilux. Quote
oldeskewltoy Posted December 11, 2014 Report Posted December 11, 2014 diff failure is more than power... it is also vehicle mass. The KE70 isn't very heavy... 1000 kilos (+ or -) You have a few options... Ford's 8.8, modified to take the E7's spring seats and trailing arms... or you might get away with a T housing fitted with Weir Performance axle diff kit - http://www.weirperformance.com/axlekitscompleterear.html Quote
kickn5k Posted December 11, 2014 Report Posted December 11, 2014 (edited) On 12/11/2014 at 9:26 PM, altezzaclub said: You're past a Skyline diff too I think. Borgys in a full weight Falcon are good for mid nine second passes. Given an e7 are half the weight it should be fine with a set of billet axels. FYI skyline, falcon and commo diffs are all pretty much the same internally all except a couple of different splines on axels. Edited December 11, 2014 by kickn5k Quote
batmo Posted December 12, 2014 Author Report Posted December 12, 2014 On 12/11/2014 at 10:20 PM, oldeskewltoy said: diff failure is more than power... it is also vehicle mass. The KE70 isn't very heavy... 1000 kilos (+ or -) You have a few options... Ford's 8.8, modified to take the E7's spring seats and trailing arms... or you might get away with a T housing fitted with Weir Performance axle diff kit - http://www.weirperfo...mpleterear.html Yeah this is something that swayed me towards this car. Had a heavy as hell VT prior and just fire saled it off asap as soon as my KE70 popped up for sale! Forgive my ignorance but could you shed some light on T series plz? Billet axles are definitely not out of the question and trying to keep unsprung weight down as well so a Hi Lux diff will be a good option but I think last resort I have a back ground with commodores which is why I was thinking BW78 based diff as I've done a few of these at 300rwkw in the heavier VS with no issues from the gearset or axles. Everything is boosted of course What I really like of the ford diff is the watts link from factory and it's something I'll really be looking at as I do this project. Has to be better than a lateral bar Quote
