liamke70 Posted November 6, 2014 Report Posted November 6, 2014 My connections in my key barrel broken for the ignition, the accessories part still works though So I'm planing on installing a start button to fix this Which wires will need to be shorted(connected to the button) Thank you Quote
altezzaclub Posted November 6, 2014 Report Posted November 6, 2014 You'll have to check wires for power as I haven't found a reliable wiring diagram for each Corolla. I have several diagrams that vary from each other. Brown should be power coming in for ignition & running. White should be power coming in for everything else. Blue/red is accessories Ignition to run the motor through the ballast is red/orange Starter motor solenoid is black/white Ballast bypass to start the motor is what is left. I can't read the colour... The "start" part of the key feed both those circuits at once. The brown comes from one fusible link by itself and feeds the ignition circuit and ballast resistor to keep the motor running through red/orange The white is from another fusible link and feeds other circuits as well as the starter motor and ballast bypass direct to coil +ve for cranking. Quote
Banjo Posted November 8, 2014 Report Posted November 8, 2014 Hi Liam, New aftermarket KE70 switches are available on ebay. http://www.ebay.com....=item3ce9d87f3e Cheers Banjo Quote
liamke70 Posted November 10, 2014 Author Report Posted November 10, 2014 thanks guys installed a start button and now works:) Quote
