Hi everyone,
After looking around for a while I have found some info on KE55 camber plates but not too much.
I have been told S13 ones fit in with only a very little amount of work and also Cusco make them but they can be very hard to get in Australia.
Do TE37 ones fit? If so what do you think of these:
https://technotoytuning.com/toyota/te37/te37-corollalevin-camber-plates
I also still have stock suspension so should this be changed before doing camber tops?
Thanks for the help.
Yes the t3 ones will fit, they also have the same plates listed for Ke30 on their site.
You won't really get any camber out of them without coilovers as the stock springs will foul on the towers.
Thanks for this. What would be the best way to get camber with stock springs or am I just going to have to bite the bullet and get coilovers? Also regarding rear camber how could I get that?
Sorry about all the questions thanks for the help
Swap to ke70 struts and springs you can max out the camber tops as they have fair bit smaller spring diameter
S13 cambertops also fit with some minor hole filing and can be considerable cheaper second hand than t3
Also you can't get rear camber.. none.. ever. Not without custom fabricating the entire rear end to accept IRS out of another car.
thanks yeah wasnt too sure if i could might look into swapping for ke70 struts. Thanks
