SurfWagon Posted August 21, 2014 Report Posted August 21, 2014 Have tried searching all over the web (including on this site) and even asking a number of exhaust shops. I have a KE36 with a 3K with twin 40mm Dellorto's and a set of 4 into 1 headers. I am trying to work out the best exhaust size and construction to suit this set-up. The car currently has a brand new 2" exhaust with a single rear muffler installed by the previous owner. After driving it back from Brisbane to Melbourne over 2 days I discovered that it was both very loud (with a huge drone) and seemed to create a sense of lag maybe due to turbulence caused by the large sized pipe for a small 1.2lt engine. What I would like to know is what diameter pipe would be suitable (just a weekend cruiser) and how should it be constructed (2 mufflers or a muffler and a resonator) to keep both the noise down and give the engine a little response back. My only thoughts would be for a 1.5" pipe diameter, a mid mounted resonator and a rear mounted muffler. Any help with this would be much appreciated. I am very well versed in terms of race car preparations and high horsepower engines and exhausts but this is something a little from left field. Regards, Luke. Quote
altezzaclub Posted August 21, 2014 Report Posted August 21, 2014 My only thoughts would be for a 1.5" pipe diameter, a mid mounted resonator and a rear mounted muffler. Yep- I took the 2" extractors along a 2" pipe to the longest 2" resonator we counld get, fitted under the passenger's floor as usual. From there it is 1.75" back to a "sports" muffler, an 'open center' tri-chamber that absorbs noise well while still flowing cleanly. That sounds good on the road and is fine inside the car, it runs with a cam and twin SU carbs, although it is still drony after a couple of hours at 100kph. That's all on a 4K. build is here with a couple of sound files- http://www.rollaclub.com/board/topic/42407-the-girls-ke70/ Quote
SurfWagon Posted August 22, 2014 Author Report Posted August 22, 2014 Thanks mate, very good info. Much appreciated. Quote
B.L.Z.BUB Posted August 22, 2014 Report Posted August 22, 2014 2" should be fine. Just whack a second muffler or resonator in. Quote
Jono.C Posted August 22, 2014 Report Posted August 22, 2014 Yeah just put another muffler in it Quote
bruce Posted August 22, 2014 Report Posted August 22, 2014 I had a 2" system, with sports muffler and hotdog resonator, which was droney/loud at 100Km. Replaced the resonator under the passenger side with another muffler and it quietened it down a fair bit, so two mufflers in total. Still kind of had a drone sound present while cruising above 4000rpm with 4 speed. So would recommend to get a 5 speed gearbox and maybe a lower ratio diff to get the revs down, would make highway cruising quieter. Maybe lay some sound deadener under the carpet and boot area. Quote
