i need to replace my timing chain since it seems to be worn.
how can i buy a new one? is there any guide to ask from sellers???
any part number / length or number of links of the chain????
Nothing spacial, just ask for a 3k timing chain at your local parts shop. The 3k should be a double. Get yourself a timing gasket set while you're there.
Hi Asiri,
There is a new after market Rollmaster 3K chain on ebay at present.
http://www.ebay.com....=item1e8eaa6f07
I've used the 3K Rollmaster on my 4K & 5K engines, as they were better than the single row chain on the later K series engines.
Always a good idea to replace the hydraulic chain tensioner at the same time. You can usually find after market ones for the 3K on ebay also.
Cheers Banjo
