Hey all,
Just wondered if anyone knew the spindle angle differences between ke20/ ke30 and ke70 struts?
For example, Ke20 struts in ke10 add positive camber due to the spindle being different angle to ke10..
Is anyone able to measure the backing plate mounting surface with the strut perfectly upright on a ke3x or ke7x strut or have any images of comparison?
Thanks
Its difficult to do precisely with your average tools which is probably why no one has really bothered but
there's this little tool called an anglecube that is a magnetic tool to find the angle as you describe, just
attach to strut housing then attach to hub flange and work out the difference to get the angle. Would
recommend to buy one and have a walk around the wreckers or something.
have done a few of those but forget where I posted and what car.. belive kp61 was 8.6 deg
easy to use, press "zero" while on strut leg and get direct readout when on disc or hub.
will see if I get time, and remember
