carter70 Posted June 3, 2014 Author Report Posted June 3, 2014 Yeah that's what I was thinking , I don't like the idea of copying people but still I don't have a very big budget. There aren't heaps of ke70's around me anyway so it's not too bad Quote
carter70 Posted June 3, 2014 Author Report Posted June 3, 2014 Anyway , I've just heard 3gst's work well in ke70's. Anyone know if those will make a ke70 nice and fun ? Or any other info ? Quote
4agebj Posted June 3, 2014 Report Posted June 3, 2014 it all depends on your budget.... yes sr 20s are better in some ways then a 4agte but then 3sgte and better then sr all depends on dollars you have to spend and if you want it to be leggal and how much work you willing to put it if its your first build i would go 4age loads of fun heaps of info on it all over the web. keep it all toyota don't go wrecking a good car a put a poxy nissan engine in it :) thats my 2 cents worth Quote
carter70 Posted June 3, 2014 Author Report Posted June 3, 2014 I'd definately be aiming for a Toyota engine , it'll probably just be whatever I can get for decent cheap and won't get me in much trouble I think Quote
4agebj Posted June 3, 2014 Report Posted June 3, 2014 srsly man go stock 4age then if your still not happy with power put a turbo on it when you have more money its exaclty what I'm doing i currently got a 4ac in myn and it still goes soo much better then a 4k i caint wwait till i put a 4age in it Quote
carter70 Posted June 3, 2014 Author Report Posted June 3, 2014 Yeah, just need to do a little more research on whether the exemptions in QLD are possible, some people say they are but others say they aren't so I'm not sure yet. Quote
4agebj Posted June 4, 2014 Report Posted June 4, 2014 la engine specss.pdf i know its a lot of info but thats the rules man it can be done :) Quote
ke70dreamcar Posted June 5, 2014 Report Posted June 5, 2014 does anyone know if i have change ke70 crossmember to fit 4age motor Quote
4agebj Posted June 5, 2014 Report Posted June 5, 2014 you need to change engine mounts and gear box cross member and change to a diffrent gear box every one uses t50 boxs you can use ae71 mounts off a 4ac Quote
4agebj Posted June 5, 2014 Report Posted June 5, 2014 I'm currently running the 4ac and t50 box out of a ae71 just gotta get some dollars for the 4age Quote
B.L.Z.BUB Posted June 5, 2014 Report Posted June 5, 2014 You need the AE71 engine cross member too (unless you buy KE Conversions 4AGE into KE70 engine mounts, comes with gearbox X member also), plus a hydraulic pedal box, plus clutch slave and master, banjo fitting for the clutch slave, AE71 tailshaft (unless you use a T18 gearbox). RWD sandwich plate. Quote
carter70 Posted June 9, 2014 Author Report Posted June 9, 2014 I have seen kits of engine mounts for 4age into ke70 for about $250 ish, would that be worth it, and also what do you do with the mechanical tacho on the ke70 if your putting in a 4age, wouldnt that be a electronic tacho. Quote
carter70 Posted June 9, 2014 Author Report Posted June 9, 2014 Thanks for the la conversion pdf too mate Quote
widomski Posted June 9, 2014 Report Posted June 9, 2014 Tach in the KE70 would be the same as in the AE71 I think. The one in the KE is definitely not mechanical. Quote
