edenhazardforjesus Posted May 22, 2014 Report Posted May 22, 2014 Hey guys I'm in the process of turbo charging my KE70 4Kc. I'm stuck on where I can get a turbo manifold for the 4k/4y/3k models. I'm located in SA so if anyone could point me in the right direction that would be greatly appreciated Quote
Taz_Rx Posted May 22, 2014 Report Posted May 22, 2014 Its not something you can just get off the shelf. You'll have to get one custom made and be prepared to pay for it. Alternatively you can just run a "J-pipe" off the stock manifold for a fraction of the cost. Click on "tar" in my signature below and you can find picks of a couple of j-pipes and a proper manifold. Quote
edenhazardforjesus Posted May 22, 2014 Author Report Posted May 22, 2014 On 5/22/2014 at 9:08 AM, Taz_Rx said: Its not something you can just get off the shelf. You'll have to get one custom made and be prepared to pay for it. Alternatively you can just run a "J-pipe" off the stock manifold for a fraction of the cost. Click on "tar" in my signature below and you can find picks of a couple of j-pipes and a proper manifold. Thanks for your reply. So what I'm getting from these photos is the a "j" shaped pipe is bolted directly on the exhaust manifold and then directed to the front of the car to give it room to bolt onto the exhaust inlet side on the turbo and then the dump pipe just plumbs back liKE normal? Quote
Taz_Rx Posted May 22, 2014 Report Posted May 22, 2014 Pretty much. You can sort of think of it as a "standard manifold> turbo adapter. It doesn't have to bring the turbo forward, just somewhere you have room for the turbo. I have seen a couple of setups with the jpipe running to the other side of the motor as there is a heap more room to play with. Quote
Robert maher Posted May 21, 2019 Report Posted May 21, 2019 On 5/22/2014 at 10:58 AM, Taz_Rx said: Pretty much. You can sort of think of it as a "standard manifold> turbo adapter. It doesn't have to bring the turbo forward, just somewhere you have room for the turbo. I have seen a couple of setups with the jpipe running to the other side of the motor as there is a heap more room to play with. Expand This is what I have done. Put mine on the other side for the room and it seemed to give a better flow of exhaust Quote
