ke30kb Posted May 21, 2014 Report Posted May 21, 2014 Hey Guys, I currently have a 1976 Ke30 Corolla with a 4K, I'm wanting to spend a little bit of money but not too much to get some more power to it. If someone could give me an idea of a starting point as I have no idea where I should even begin that would be great. Maybe even if someone lists everything I should do that's worth it, I'd greatly appreciate it. Cheers. Quote
Taz_Rx Posted May 21, 2014 Report Posted May 21, 2014 http://www.rollaclub.com/wiki/index.php?title=Tech:Engine/K_Series/How_to_build_a_tough_K_motor Quote
altezzaclub Posted May 21, 2014 Report Posted May 21, 2014 Look at the builds and PM some people... Here's ours- http://www.rollaclub.com/board/topic/42407-the-girls-ke70/ Quote
Crostek Posted May 22, 2014 Report Posted May 22, 2014 How much is a “little money” are you looking to spend? Are you going to pulling it out and change cam, new pistons some port work or just some bolt on bits to get a little more fun from it. Most 4k's suffer from restrictive air/fuel into the motor and exhaust out of the motor So a good cheap starting point would be a set of extractors with a 1 and 3/4 inch exhaust system (not good for a fully worked engine 2" would be better) A down draft Webber and decent air cleaner, and change the distributor to electronic one from a Liteace motor to give better spark and no more “points” problems The above list set me back $800 and my KE70’s rwhp from 41 to 62 (motor is also quite fresh only done 20,000km) I could get a lot more if I change the cam, have the head porting on both the intake & exhaust done, and I can still use the same weber and exhaust I have already invested in. But as the car is my daily I can’t do with it off the road for that long to get the motor out. Quote
coln72 Posted May 22, 2014 Report Posted May 22, 2014 Or you could dig up a 5k and enjoy all the extra torque ;) Quote
