hi guys,
I've seen some people drill the tops of the strut tower to fit these but i was wondering has anyone drilled out the camber plate and relocated to stud to fit the KE55 spacing.
i mean its easy to push out the stud in the camber plate, mark out the new position and repress in the stud. Therefore you don't need to drill the strut tower
any on done this?? curious
The issue is that generally you arent moving the stud far enough to get a nice clean hole in the camber plate.
you can always just make a new camber plate. get 2 bits of aluminium laser cut the same but with the holes in the proper spot.
Here is some photos of how close the holes are, from those photos i think its fair to say you wont get enough material in the camber plate to drill a new hole.
http://www.rollaclub.com/board/topic/50551-ae86-front-end-suspension-brakes-into-ke55/
