ATOYOTA Posted May 4, 2014 Author Report Posted May 4, 2014 I chased the -ve coil wire back through the dash and found an intersecting wire so I followed that and found I had also piggybacked the tach constant to it which as I found out was sapping the power. I chose a different wire for constant and BROOM, started right up. Cheers for the help, couldn't have done it without you. Tach says it's idling at ~1150rpm warmed up. Is that a bit high? Quote
altezzaclub Posted May 4, 2014 Report Posted May 4, 2014 Not vital- The KE70 idles at 1000rpm. Drop it back and see if its happy running slower. If its stock it should idle at 600 without a problem. Quote
