SM Hunter Posted April 3, 2014 Report Posted April 3, 2014 Hey, a coupple of days ago i desided to build myself a cart form parts i got laying arround... the plan.. welded together the frame.. note. I'm not good at welding but i do my best.. bought some wheels started making the steering working steering found some bearings for the rear axle.. got a flywheelnut and a gear selector form a friend conected the wiring haness and bolted on the flywheel and carb, and it fired up! welded on a bar .. ahead of that I'm going to make a plate where ill have my feet, and were the pedals will sitt gear selector holding in the gear lever ... only need a bar between the gear lever and selector on the motor and thats how far iv gotten.. started on 31. mars :) Quote
SM Hunter Posted April 4, 2014 Author Report Posted April 4, 2014 (edited) found a small sterring wheel and bought some threaded poles ( or whatever you guys call it) and made the steering a lot better Edited April 4, 2014 by SM Hunter Quote
SM Hunter Posted April 5, 2014 Author Report Posted April 5, 2014 found short some 20mm bars.. drilled and taped them.. made some excelente spindles working steering system made the gearing work, and reinforced the engine mounts aswell added a joint to the steering wheel stick made a springed gas pedal stiff "swingarm" made housings for the bearings... now i need to get hold of a braking disc etc.. and a 20mm rear axle.. :) Quote
SM Hunter Posted April 6, 2014 Author Report Posted April 6, 2014 (edited) welded the seat to the chassis.. welded a plate to mout the coil and ign. switch stuffed the wiring harness under it made a plate to mount the sprocket to a axle need to shorten the chain a bit a bit of thinking left... Edited April 6, 2014 by SM Hunter Quote
