leigh Posted March 15, 2014 Report Posted March 15, 2014 Just wondering what people have done when they efi there ke30 / 55 etc.. The stock pickup seems to have an OD of 6.5mm haven't taken an internal measurement yet. Was thinking it might be abit small as the efi house and pumps I'm using seem to have and ID of 8mm etc Cheers Leigh Quote
Taz_Rx Posted March 15, 2014 Report Posted March 15, 2014 (edited) All of my carby turbo days were using the stock pickup. The return into the tank is only really a breather though so I t pieced into the filler neck breather. Remember you're not always going to be at full throttle and fuel usage so the surge tank will help somewhat making up for the small pickup ;) Edited March 15, 2014 by Taz_Rx Quote
OKE055 Posted March 17, 2014 Report Posted March 17, 2014 Mine has been modified with an 8mm pickup it's quite easy to do Quote
ke70dave Posted March 17, 2014 Report Posted March 17, 2014 I used the standard sized pick up on my ke70, but i had the local hydraulics mob braze some slightly larger barbed fittings onto the end of the pipes so it was easier to attach slightly larger hose to it. Quote
