nath-sr Posted March 2, 2014 Report Posted March 2, 2014 Hi after puttin in a smallport 100kw into my coupe I'm a fitter welder and own a workshop can do all myself but just after some advice on mounts and crossmembers can I use ae71 engine and gearbox x member as direct bolt up or is this a false claim? Does anyone have a sketch if so of mounts and x member if custom ? Best to use t50 box? And is there a bolt up tailshaft or again a cut and shut job any info appreciated cheers nath. Quote
B.L.Z.BUB Posted March 2, 2014 Report Posted March 2, 2014 There is a guy who makes kits for this install. AE71 stuff wont work. You will need a T50 minimum which means you will need a hydro pedal box. No bolt up tail shafts you will need custom. Quote
Jordanrolla Posted March 2, 2014 Report Posted March 2, 2014 I hear if you use the ta22 T50 gearbox it has the same spline for the manual KE30 tailshaft Quote
