Hey,
so i'm installing central locking in my ke55, i've got the front doors working perfectly but i've run into a brick wall when it comes to the rears. I've tried a couple of positions but the angles just won't work.
the redline in the picture is where i've also tried mounting it.
Any suggestions/ideas?
thanks
Looks pretty clear to me B-Lugg?
I think you are just going to have to try and get it pulling as straight as possible and make sure there is as little flex as possible.
Easier said than done I know.
Edited by parrot
Thanks guys, i'll try and play around with the rod.
Its it hard to pull or push the lock by hand? You might need to lube the mechanism if there is too much load on the solenoid.
It's definitely harder to push or pull than the fronts but i thought that would just be because of the different design. what should i lube up the mechanism with ?
