If you are using SW20 KYB AGX dampers then the T3 upper spring seats will fit, don't even trip.
However you may need to use a spacer between the upper spring seat and the BC camber plate.
  On 2/20/2014 at 5:48 AM, B-Lugg said:
Although I'll probably end up getting decent digital Kingchrome ones or something, over all my tools breaking.
I have Kincrome vernier calipers, I really like them but they were about $80. Although I use them all the time so they were worth it. I'd avoid digital ones because I've seen too many faulty ones.
I have Kincrome vernier calipers, I'd avoid digital ones because I've seen too many faulty ones.
Sweet - I have a quick fix that might work but t3 will be my next step.
Duly noted, I'll get mum to keep an eye out for work.
Alright - I grabbed some tops thanks to a nice bloke off Facebook. Shout out to that guy!
I had them lathed out to fit the strut at Mark Barnes Engineering in southport - easy work, but I'm happy with the work they did. Zero stuffing around.
Now the only problems I have left is spacing the spring hat from the camber top as I think they will foul as soon as I add any negative camber to the strut.
I'm also in need of a specific bolt with a sleeve (Nice normal coilover shock bolts) as the standard shock bolts are crazy wide.
TL;DR - Need to figure out how to space c/tops from upper hats - some perfect size washers should suffice
Also need to figure out where to get bolts for c/tops and shocks - ones with sleeves similar to lug nuts/normal c/top bolts.
I'll upload some photos tomorrow to better show the problems.
Edited by B-Lugg
The problems (At least they look pretty now)-
Heading down to the fasteners joint on Monday to try my luck - I doubt they will have something with a sleeve or something on it though. With a little luck I'll be able to retrofit some shit.
kcaky3G.jpg?1
5Nq9VUC.jpg?1
Make a short sleeve out of some tube? It doesn't need to be connected to the nut does it? Or just tighten the top nut up really tight and don't worry about ;)
Ideally I would like it to be able to catch as much thread as possible and the knob to adjust the shock to be exposed so I can change it on the fly, so an open end lug nut style would be perfect.
If the fasteners dude doesn't have anything to suit - I'll take the ghetto route! (Tube Sleeve + Nylock nuts)
