clean55 Posted January 27, 2014 Report Posted January 27, 2014 (edited) Hey guys. now i have found myself in a very hard place at the moment. I'm in the process of draw through turbo setup on a 4k ive done all the hard work and it should start. it has an zenith SU carb heaps of fuel coming through it, but it just wont fire. spark is good and everything else working perfectly, i just can't get it to start ANY help would be well received I have also tried tipping raw fuel into the manifold, and using aerostart everywhere I'm literally out of ideas. Edited January 27, 2014 by clean55 Quote
Clapped out Posted January 27, 2014 Report Posted January 27, 2014 (edited) Try putting raw fuel into the manifold again, hold the piston open wide in the carby with your finger and crank, see what happens I guess? By rights with fuel, spark, compression it should fire, or even kick, oh and does the carb have oil in it? cheers! Edited January 27, 2014 by Clapped out Quote
KEI069 Posted January 27, 2014 Report Posted January 27, 2014 Did it run before the turbo was fitted? If it's got fuel and spark then I'd be looking at timing! Keep us updated Quote
clean55 Posted January 27, 2014 Author Report Posted January 27, 2014 (edited) I have no idea if the carb has oil or that it needed oil.. timing is at TDC which is should at least fire at hmm holding open the piston is a terrifying idea as it has backfired out the carb a couple times. but nothing consistent. Edited January 27, 2014 by clean55 Quote
Mechanical Sympathy Posted January 27, 2014 Report Posted January 27, 2014 Backfiring out the carb - is it possible the distributor is 180 degrees out? Quote
clean55 Posted January 27, 2014 Author Report Posted January 27, 2014 nah man double checked re check an repeated that so much to no avail. Quote
clean55 Posted January 27, 2014 Author Report Posted January 27, 2014 and yes the motor ran well before turbo Quote
Feral4K Posted January 27, 2014 Report Posted January 27, 2014 Hello drawthrough! ill put my money on the internal wastgate being jammed open and all that fuel is goin out the back door.... Quote
clean55 Posted January 27, 2014 Author Report Posted January 27, 2014 Hello drawthrough! ill put my money on the internal wastgate being jammed open and all that fuel is goin out the back door.... but in that case when I'm putting raw fuel and aero start in the manifold after turbo t should fire :S Quote
Feral4K Posted January 27, 2014 Report Posted January 27, 2014 Youd think so, providing your spraying it in after the turbo ie bypassing it alltogether!, if not and the wastegate is open your never, gonna get the fuel out of the front cover and into that manifold, little own any air, also well worth putting a compression tester on it to make sure it hasnt blown the comp rings off the pistons, just throwin some ideas at ya, iff all fails contact KIKN5K on here I'm sure hell be handy lol. Quote
altezzaclub Posted January 27, 2014 Report Posted January 27, 2014 Does the SU have the choke fitted and pulling the jet down? There is no pump jet so they will run very lean at starting rpm. Try taking the red flexible hose off and spraying engine start in there. That would bypass the turbo and confirm that all other systems are working OK. You could try tow-starting it as cranking speed is very low and once it is running you mght find a turning problem. Stick a few degrees of advance on too, if the total advance worries you don't take it over 2000rpm when its running until you've sorted everything out. Quote
Taz_Rx Posted January 28, 2014 Report Posted January 28, 2014 Umm...what are you on about? The waste gate is on the exhaust side of the turbo.... so the fuel has to go through the motor before it goes anywhere near the gate. Does it fire at all? Quote
ke70dave Posted January 28, 2014 Report Posted January 28, 2014 yeah I'm confused at the wastegate comments. Altezzas comment recomendation fo putting fuel (or any propelant) in after the turbo to see if it kicks over is where I would start. Quote
Taz_Rx Posted January 28, 2014 Report Posted January 28, 2014 Only thing I can think of is he's thinking that an open gate will cause the turbo to not spin and suck mixture through the inlet..... but at start load/RPM it aint going to do squat anyway. The motor itself should create enough vacuum to such the mixture in. Quote
clean55 Posted January 28, 2014 Author Report Posted January 28, 2014 ye there is a tonne of fuel going in. and i would believe enough air.. as i said ive sprayed easy start into the manifold above cylinders and wont fire.. ive also put some on top of the piston through spark hole and it wont fire.. and yet it had perfect spark timing is TDC and engine was running beautifully not 2 weeks ago so comp should be fine... In sayign that one thing that suprises me is when I'm cranking the engine after like 20 seconds of crank fuel starts to piss out the bottom of the joint between carb and turbo. if that helps. Quote
