I've recently bought a '92 gti as a project car. What is everyone's opinion on whether to turbo or supercharge? Fixing up the body first... engine last :-)
Pros and cons of both please
Supercharger- instant power right through the range and only comes on if you want it to. Put a switch on the floor under the throttle.
Sounds WAAYYY.. better than a turbo, that banshee howl cannot be imitated!
Reed's right, but how much time do you spend driving at the top revs of a turbo car, once you get past the lag at all the normal around-town revs.
While I do love my supercharger and will keep it charged I know it will never be as fast as it could be. Plus theres no easy boost adjustment. But that howl, it even makes a kind of flutter when you change gears from the ABV now that I have maxed the boost out.
A big plus for the supercharged route is that on a AE92 you could easily find an entire bolt in ready to go engine pretty easy from an AE101.
Is the price for both about the same? Obviously it will be for the 4age which is quick... but quicker is better. I think personally it will be about the sound and feel in the end more than the speed :-)
A turbo one will be more expensive, it will have a lot more aftermarket bolt on parts. I bought my GZE for $1500, got lucky as it had HKS cams in it. Came with ECU, loom etc. Where are you located?
EDIT: The GZE is a great little engine, you sacrifice some of that raw GE N/A noise, but dayum that SC howl <3
Edited by B.L.Z.BUB
I think I'm leaning more towards the supercharge option. Located in Perth WA
A good intercooler setup has a lot more positives compared to the negligible lag. The big things is to choose your turbo wisely. Most people that complain about lag are using the wrong turbo.
