Robski Posted November 19, 2013 Report Posted November 19, 2013 Just wondering if anyone has or know anyone who has tried or is using theTechno Toy Tuning weld on front suspension??? Link is below https://technotoytuning.com/toyota/ke30/weld-front-coilover-kit-ke30-corolla Quote
B.L.Z.BUB Posted November 19, 2013 Report Posted November 19, 2013 (edited) I havent personally used them and I wouldnt. It is a cheap alloy sleeve with a 'ground control' collar that you weld on that the sleeve sits on. So the actual threaded sleeve isnt actually attached to the strut. it is held in place by welding the lower collar on at a point that makes the sleeve sit slightly proud of the top of the strut and the gland nut screws down and clamps it in place. You can buy similar cheap kits off eBay for $100. EDIT: I think they use a grub nut to lock the adjusting ring too, instead of two ring tightened against each other. Edited November 19, 2013 by B.L.Z.BUB Quote
Robski Posted November 19, 2013 Author Report Posted November 19, 2013 Cheers mate, I was thinking they may be something along those lines but thought I'd ask Just in case. Quote
B.L.Z.BUB Posted November 19, 2013 Report Posted November 19, 2013 don't get me wrong they probably work fine, plenty of people use them. Personally I'd want all my shit welded solid which is why I used an HSD kit. Converting your stock struts is gonna limit your shock availability also. A strut upgrade would be my first point of call. AE86 is an easy bolt in option. Quote
Robski Posted November 20, 2013 Author Report Posted November 20, 2013 Cool so if you don't mind what have you used (complete front setup) and how does it work?? 5 stars or is there some areas for improvement. Quote
Robski Posted November 20, 2013 Author Report Posted November 20, 2013 I have been hearing a lot of people asking the question about putting AE86 adjustable coilovers into the KE30, however there has been no direct answers. CAN YOU USE AE86 ADJUSTABLE COILOVERS IN THE KE30???? and if so what do you need to complete the conversion?? Cheers Thanks for your help. Quote
filfrederick Posted November 20, 2013 Report Posted November 20, 2013 i used a fortune auto set I'm my e30 recently, you just cut off the original strut tube a few inches from the bottom and a steel sleeve slips over the old tube and weld it on at the base. very happy with the quality and only $750 landed complete with camber tops. they make them in heaps of sizes so probably have something to fit a ke30 there is a trader on toymods that i got them through Manon Racing Products in New Zealand, he is the Australian dealer. 1 Quote
Robski Posted November 20, 2013 Author Report Posted November 20, 2013 Cheers thanks Filfrederick I will check them out. Quote
Robski Posted November 21, 2013 Author Report Posted November 21, 2013 On 11/20/2013 at 7:58 AM, filfrederick said: i used a fortune auto set I'm my e30 recently, you just cut off the original strut tube a few inches from the bottom and a steel sleeve slips over the old tube and weld it on at the base. very happy with the quality and only $750 landed complete with camber tops. they make them in heaps of sizes so probably have something to fit a ke30 there is a trader on toymods that i got them through Manon Racing Products in New Zealand, he is the Australian dealer. I contacted MRP in NZ and they said they could build me a set of fronts to my specs that, as you said, just need to be welded to the original strut tube for $900 delivered. I am reading some reviews on the Fortune auto 500s and they seem to be solid (from what I have been reading), so this may be a way to move forward. If anyone also has some experience with the Fortune Auto 500s I would appreciate some feedback on them (including what spring rates for the front of a mainly street car, occasional track and strip). Quote
