Hi Guys
My car is a JDM AE 101 FX this car has been a project build for a few years and after reading snapz build I decided to post mine to also help others along.
At present it sits a pile of parts waiting to be assembled but being unemployed at present the car is taking the back seat.
Engine is an AE 101 4A GZE hybrid crank is from an AE 101 4A FE
Here is the list of parts and what has been done so far
Head has been port and polished and matched flowed, low friction valve guides have been added and also 1mm over stainless steel oversized valves.
Cams will be Colt cams tri flow cam shaft OEM valve springs and HKS retainers
Block is awaiting to be bored to fit 82.5mm 10.5:1 static CR CP pistons
Rods are Belfab racing custom H beam rods 20mm small end 40mm big end
Crank has been knife edge and blanced
ARP head and main stud kit have also been added
List of other goodies:
Vernier cam gears
Aquamist water injection
NOS kit for cryogenic FMIC cooling
B18 twin scroll manifold with GT4292 Godspeed twin scroll turbo
Madza Axia electric power steering pump
Megasquirt DIYPNP ecu with electronic boost controller
Precision turbo 880cc injectors
Trd front and rear anti roll bars
Wilwood Superlite Calipers
Ksport Kontrol pro coilovers
I may have forget a few other goodies but will post them later
  • 8 months later...
Okay guys it has been awhile since I have last post some updates are coming your way soon. Should be getting my head back from the machinist on Tuesday will post some pics. The head has been port matched and polished 1mm oversize valves with a 5 angle cut and bronze valve guides.
  • 4 months later...
Updates I am awaiting an ARP main stud washer that was misplaced by my local machine shop.
What has been done
Pistons and Rods have been connected
Fuel Pump assembled
Crank has been installed and just needs to be torqued
Work has been slow but steady
