Hey I'm new to rollaclub so excuse me if I have posted this in the wrong place or something. Anyway I recently brought a Toyota corolla ke55 everything is working fine but I have to keep on the gas for it to not stall, I've been told to get the carby looked at or get it tuned ? Just wanted some other opinions
My first guess would be the fuel cut solenoid on the carby and that its either not connected to power or its not working.
Next if the solenoid is working is to check the rubber hoses for splits etc.
Next is to check for air leaks around either the base of the carby or between the intake manifold and head. Squirt a bit of wd40 or something similar around these areas.
Apart from that "K" series carbies are pretty cheap.
  • 2 months later...
