Winding the mixture screw out would increase revs. Are you sure you're playing with the mixture screw and not the idle stop ?
Base setting for the idle screw should be 1.5-3 turns out from seated. Ignition timing will also affect idle speed.
Why did you rebuild the carb, what were the symptoms before ?
i was told that it is opposite on aisan carbs and not quite sure :/ haha , and the timing seems fine , the plunger wasent working and and it was dying and shit
Timing seems fine ? or is fine ?
If winding the mixture screw in/out makes no (or very little) difference to the idle speed, I'd suspect a leak or an assembly fault, particular if the engine falters once the load comes on.
