The Toyota K Series engine manual lists an NGK BP5EA-L or EP5EA for the Australian 4K & 4K-C engines. However, I think most people use the NGK BPR4EY or BPR5EY.
However, if your 4K is a 4K-U, (with dished piston tops) then you must use the long reach NGK BRE527Y. These were common with some early Falcons & you'll ocasionally see them on special in SCA and the like. I've always found NGK to be an excellent spark plug !
Cheers Banjo
