B.L.Z.BUB Posted January 12, 2014 Report Posted January 12, 2014 You need the XT steering arms or they wont fit with RCA's. Quote
stu84ke70 Posted January 14, 2014 Author Report Posted January 14, 2014 On 1/12/2014 at 7:32 PM, B.L.Z.BUB said: You need the XT steering arms or they wont fit with RCA's. I have them bolted in now and seem to fit fine, what I'm having problems with is the spring fouling the shock towers even tho I used the ae71 tophat. Quote
B.L.Z.BUB Posted January 14, 2014 Report Posted January 14, 2014 (edited) You got them to fit with RCA's? How? What steering arms are you using? They barely fit without them, you need to mash the end of the LCA to get rotor clearance. You can't use XT springs. You have to either weld on the stock spring perch or convert to coilovers. Or I suppose you could get a new spring made to suit. Edited January 14, 2014 by B.L.Z.BUB Quote
stu84ke70 Posted January 14, 2014 Author Report Posted January 14, 2014 (edited) On 1/14/2014 at 5:42 AM, B.L.Z.BUB said: You got them to fit with RCA's? How? What steering arms are you using? They barely fit without them, you need to mash the end of the LCA to get rotor clearance. You can't use XT springs. You have to either weld on the stock spring perch or convert to coilovers. Or I suppose you could get a new spring made to suit. I'm using stock ae71 steering tubes,tierod ends with xt130 steering arms. Edited February 18, 2014 by stu84ke70 Quote
stu84ke70 Posted January 14, 2014 Author Report Posted January 14, 2014 (edited) Everyone say's that the xt130 strut is an upgrade and they bolt straight in, but the ae71 top spring retainer does not fit the xt130 spring (even if you flip the spring) and the xt130 spring fouls the shock towers?.So what do you use the stock ae71 spring, don't know what to do now, I feel that I have wasted my money buying this setup any help would be appreciated or advice from someone that has done this conversion. Edited January 14, 2014 by stu84ke70 Quote
B.L.Z.BUB Posted January 14, 2014 Report Posted January 14, 2014 (edited) What steering arms are you using? They do bolt in, unfortunately they also need to be modified. You can use the original Corolla spring but it wont seat properly on the lower perch and you may need to wire it in. I didnt have this problem as I converted/shortened mine into coilovers. Edited January 14, 2014 by B.L.Z.BUB Quote
stu84ke70 Posted January 14, 2014 Author Report Posted January 14, 2014 (edited) On 1/14/2014 at 6:07 AM, B.L.Z.BUB said: What steering arms are you using? They do bolt in, unfortunately they also need to be modified. You can use the original Corolla spring but it wont seat properly on the lower perch and you may need to wire it in. I didnt have this problem as I converted/shortened mine into coilovers. Everything is stock ae71 gear apart from the steering arms and the struts, brakes and hubs Edited February 18, 2014 by stu84ke70 Quote
B.L.Z.BUB Posted January 14, 2014 Report Posted January 14, 2014 AE71 steering arms wont fit on the bottom of XT130 struts. Quote
stu84ke70 Posted January 14, 2014 Author Report Posted January 14, 2014 I can't understand it, i've seen countless photos and post about people running xt130 struts brakes and so on without welding on coilovers yet nothing seems to line up or work WTF? am I missing something. Quote
B.L.Z.BUB Posted January 14, 2014 Report Posted January 14, 2014 (edited) Everyone says everything fits without modifications. Trust me, I have had to modify everything I have put on my car that 'bolts straight in'. Have you bolted the struts to your steering arms? Edited January 14, 2014 by B.L.Z.BUB Quote
stu84ke70 Posted January 14, 2014 Author Report Posted January 14, 2014 On 1/14/2014 at 6:15 AM, B.L.Z.BUB said: AE71 steering arms wont fit on the bottom of XT130 struts. Yes I know there xt130 ones. Quote
B.L.Z.BUB Posted January 14, 2014 Report Posted January 14, 2014 Well you will be fine to bolt it all in apart from the spring. The steering arms make you lose lock, the steering will be slower but it will be far lighter. Quote
stu84ke70 Posted January 14, 2014 Author Report Posted January 14, 2014 Sorry mean't to say xt130 steering arms not RCA's. Quote
stu84ke70 Posted January 14, 2014 Author Report Posted January 14, 2014 On 1/14/2014 at 6:22 AM, B.L.Z.BUB said: Well you will be fine to bolt it all in apart from the spring. The steering arms make you lose lock, the steering will be slower but it will be far lighter. Yeah my plan is to cut and shut the steering arms to get my lock back, now to work out what spring to use. Quote
B.L.Z.BUB Posted January 14, 2014 Report Posted January 14, 2014 I did pretty extensive research and couldnt find a stock spring to use with stock struts and stock E7 top hats. Not saying there isnt something that will work but I didnt come across anything for months when I was planning on using them. Quote
