Hey lads, plan to build my 5k soon and wanna know if there's any suggestions or ideas on what way to go. I've been collecting bits for years and now have... Twin 40mm webers with manifold, ported 5k head, electric dizzy and pacemaker extractors.
Now other than a cam and a balance is there anything else I can do to make more power??? Any ideas will be tops cheers
  • Replies 52
yeah man all over that guide, built a few 3ks and such but never really worked a 5k, just weber and extractors. now i got the twins and the worked head just curious what others have done with ther 5ks and power they got, its only ever gonna be a weekender. i saw some gillys for sale the other day, ther alright, not really in to them, sick car but
cam is hydraulic and will leave it that way, no solids, i get the shits with adjusting rockers. Pistons are standard, bores are slightly oval shaped according to my inside mic's. No idea on the piston scenario of dished or domed or what. i know ther was info about 4age slugs and suzuki bike pistons also i think.... compression would be great but it will only recieve ultimate so 9:8 to 1 to 10;1 will be the desired ratio.
No other options i can think of really stand out, i have adjustable cam gear, will get flywheel lightened, bottom end balanced, other than slugs i think its all i can really do. n/a of course
How long do you want it too last and how much money do you want to spend.
Block dipped, bored 1.5mm, blue printed
Dry sump oil feed
You could have your crank knife edged, shot peened & polished
Forged and shot peened conrods
Polished and balanced cam with grind
Roller rockers on a micro polished rocker shaft with double valve springs
Over sized titanium valves
Ceramic coated extractors
Electric fuel pump to delete mechanical
Crank angle sensor with quad coils or magneto ignition.
I could just go on.
Edited by GJM85
yeah nah not overly alot of money its a stinking ke35! i have the webers and head, more just after bottom end info and what not, ideal cam, knife edged crank maybe, how much success is acheived from all that hard work? is it worth upping compression ratio or just skim head an be done with it. i don't wanna spend to much on the rebuild
ive got a set of twin 40mm webers with manifold, that was running on a 4k..... doenst make sense to try swap all shit over to something and make manifolds when its sittin there. would be hell ʞ©$ɟing cool but
Webers are ssooo much easier to get your low rpm and low/part throttle perfect. I've tuned both and id I'd have a DCOE style carb over a bike carb any day.
Edited by kickn5k
Dry sump oil feed
I could just go on.
please do go on
  On 8/16/2013 at 8:40 AM, TOMMYS Ke 11 said:
Have a read of Thomas thread ( TOMMYS Ke 11 ) worked 5k 110rwhp .
Cheers:- Stuart (Thomas dad) :wave: .
any chance you can link the thread
i will get in on this i have a worked 4k with twin 40s ... but i scored a 5k i was planning to go to town on so i was chasing similar info
