Hi
I'm a new member & am stumbling through all this as never been on a forum or blog whatever before
Have a KE 30 4 door. Ex mother inlaws. 92,000 klms genuine
Clutch is slipping badly & may need another flywheel unless it will machine ok
Rubbers & door tracks where window goes up in door frame are shoddy
Any ideas where can get??
Also want a couple of original manuals as the heater is working but I think one cable may have slipped or broken
I don't want to wreck the interior to start pulling things apart without knowing where all tj\he catches are
I am in Melbourne
Would also like to join the corolla club there as this is normally garaged & only driven once a month
Any suggestions would be greatfull
Regards john
Welcome. I'm new too. Show us some photos of your low km gem!
http://www.rarespares.net.au/rarespares/ProductPage.aspx?product=COR16
Rare Spares have the door rubber items you're looking for.
http://bit.ly/149S95K
http://bit.ly/14Uozx9
Manuals can be found on eBay fairly cheaply. The earlier manual is relevant to the KE30 but the later one has the information on removing the heater that you desire.
Edited by Mechanical Sympathy
The rubber stuff the window slides is called "flocking". If you search on that you should be able to find an old thread of mine, I got some from rare spares I from memory noted what car out was from as they didn't have stuff specifically for a corolla.
As for the heater controls, I doubt they would snap. Stock your head under the dash and follow the cables, you might find one has come unclipped. What exactly makes you think one isn't working anyway?
the rubber stuff that goes around the window is called Bailey channel and I just got it from rare spares and there is the right part number for a ke30 ,for the four doors it cost just under a $100, but I have heard that you can get it from Clark rubber as well and its a bit cheaper ,it will fit and do the job well but not a corolla true fitment
Bailey channel rubber can be bought by the meter at Clarke Rubber pretty cheap. 45 it in the corners with some good rubber glue and you're away laughing.
