SM Hunter Posted November 13, 2013 Author Report Posted November 13, 2013 further more cutting and welding had no more "clean" metal so had to use some used metal :) JDM welding :P done i have to trim of some of the inner thing there.. its a bit to wide :) changed the fuel pump, managed to snap a brass onection instide one of the holes... :) made a new , heavy duty throttle wire holder still have to modify a bit where the wire is attached... had no more plate for this hole :( got my extra lights thinking of painting them white and adding these cibie stickers ? :) any thoughs? ony missing a thread tap and 1 conection to move the oil filter .... :) Quote
SM Hunter Posted November 15, 2013 Author Report Posted November 15, 2013 painted and added cibie stickers started welding on the front fender if you look at the pic above you se a hole in the upper left corner ... gone now matalpaint need to take the engine bay when i take the engine out again... but maybee il do it with spray cans insted of a brush.. made mounts for the mudflaps on the right side then i painted it all white with metal paint test fitted the extra lights Quote
SM Hunter Posted November 18, 2013 Author Report Posted November 18, 2013 (edited) welded some mounts for my chin spoiler adjusters :) welded and primed the right fender :) done with all the rust removing on the right side of the body :D :y: Edited November 18, 2013 by SM Hunter Quote
SM Hunter Posted November 19, 2013 Author Report Posted November 19, 2013 brought a propper camera to the garage today :) made a little instrument panel... going to add more lots of space for more :) thinking of placing it here... Â Â Then I'm thinking of moving the battery to the trunk and then laying a cable through the car with a main switch in the instrument panel. both for safety rasons and in case of anything using power when its not suposted to :) what do you think? Quote
SM Hunter Posted November 24, 2013 Author Report Posted November 24, 2013 https://www.facebook.com/photo.php?v=758081997551795¬if_t=video_processed got it running :D had to change the carb , fuel line and vacum line to get it running from fuel coming from the pump, the old carb was plugged in some why... :) Quote
SM Hunter Posted November 24, 2013 Author Report Posted November 24, 2013 anyone got some info on turbocharging a 5R ? / turbo on carb cars in general . i don't want a drw trough type... i want a the carb after the turbo so i can have a intercooler , then i will need to make a pressure pox for the carb, but how is it with the jetting etc? will i need a new carb ? :) anyone got some info? :) Quote
Skellington Posted November 25, 2013 Report Posted November 25, 2013 There is a toyota site called 3tcgarage.com. They turbo the 2 and 3t engines. They are pros when it comes to turboing old motors with carbs or efi. The site has just been redone, but I have had good luck with people being helpful. Quote
SM Hunter Posted January 4, 2014 Author Report Posted January 4, 2014 (edited) bah... gave up the 5r and the turbo for now... maybe ill go back to that later but not now, ... for now i have put the 1,2 back inn.. started fixing rust on the other side, holy fu*k this car is rusty! took off the door for easy accses put in some plates on the undeside , only dot welded and then a plate on the top.. note: this wleding is not done, iv just dot welded it ... iv also added a coupple of more switches to my instrument panel.. i love the inside of my 20! Edited January 4, 2014 by SM Hunter Quote
SM Hunter Posted January 5, 2014 Author Report Posted January 5, 2014 striped the interior did not get the bakcseat out.. how do i do it ? started making a cage aswell.. thinking i need to make something like this? Quote
SM Hunter Posted January 6, 2014 Author Report Posted January 6, 2014 reinforced the foor found some feet for the first bar welded them on bolted in started making some bars that will go bakwards and down towards the trunk.. Quote
SM Hunter Posted January 6, 2014 Author Report Posted January 6, 2014 thanks :) looks like I'm going for a full cage :) reinforced the floor :) and made 2 plates, witch ill use as foots for the front legs :) Quote
SM Hunter Posted January 7, 2014 Author Report Posted January 7, 2014 done some more :) mmhhhhh the rusty bar is only taped to see how it would look :) one pleased me! with a bit to small car... Quote
SM Hunter Posted January 22, 2014 Author Report Posted January 22, 2014 Done! my welds are getting better, even tho i don't really know how to weld... had a 10 min course then i set of learning myself... rust cut out moar rust, need to cut out more here :P and then the back panel "nagasaki" currently been working on both my bikes... the ones in the pic... one needs a new rear wheel bearing and the other one needs new sprockets and chain..+ lots of small things :P Â Quote
SM Hunter Posted January 22, 2014 Author Report Posted January 22, 2014 arrrghhh.. all the pics gone, for a coupple of days.. :) they have been viewed to many times lately :P more welding , finsed the canal :) not toadaly finished :) Quote
