ill be getting new rings and new rod bearings and maybe new valve stem seals ill look into it..
ended up having a rod through the wall of my 3k again... this thime it knocked the starter away and snapped both bolts holding it...
now idea how this happend, filled oil the day before and i have NEVER touched the rodbolts/rods/crank... ?
started knocking and i knew what it was and was not in the mood to fix up a little 3k engine when i have a 2tg i need to fix so i just drove it home, well almost drove almost 10km with a SERIUS knock then 100m away from my house the rear wheels locked up..
I'm fed up with K series now..!
anyways drove 500kms with a couple of friends to get this beauty! 2tc from a ta40.. same block as the 2tg so bolts up to the t50 gearbox= 5 gears and 1.6!
a bit ugly but I'm hoping a round with the seamer will fix that, i got quad carbs laying arround for this head.. dunno if ill mount them on or not :)
washed :)
2T-G and 2T-C
gearbox mounted
in the car still lots to do
had to use the 2T-G exhaust due to the 2T-C hitting the pitman arm, 2T-G is ALOT more compact!
i also got a gasket set at my local toyota dealer, they are begining to know me so i got 25% off!
Edited by SM Hunter
got it started, had to adjust the igintion breaker and change the oil, and trans oil, some fresh fuel and it fired right up :)
started welding up the exhaust, this is 2" then the rest is 2,5" and a see through silencer in the rear
tacked up
need attach the gear lever, some wires and some hoses then its good to go
well thanks guys, now i went to a Japanmeeting on saturday...
sunday its a whole diffrent story... :bash: luckly i had a friend nearby with a tracktor so we managed to get it up before the cops/ other poeple saw it
Edited by SM Hunter
its not, "just a bent front plate and the bar under the radiator. i hit a BIG rock... ill post some pics later today of the car...
i was lucky, missed all the trees!
I don't see any big rocks in the photos.. were you one the road when you hit it?? ..or was it a wombat that then walked away?? :laff:
That seems to be the favourite excuse in Australia, wombats or kangaroos!
here it is, its not gigantic, but its huge enough when you hit it in like 70km/h an move it almost 2 meters with the front of a Ke20..
my keys on top of it
front end..
anyways, took the car to Rudskogen the day before Gatebil---> Toyota Trackday. almost hang in there with the GT86's ( the one with crappy tires and gutless drivers)... you could say me and my friend when all in, inner front tire lifting, downshifting in to get it sliding into the turns etc... the Track staff was laughing and clapping their hands when we drove so i call it a win! it was a fun experience and will be repeated, with a camera! we both when out of power on our phones pretty quick
out pit.. here is me talking to a fellow KE owner, he had a KE30 with a 2T-B and T50...
anyways my mate managed to get a crappy film the first lap, did not know the track and was taking it easy when it decides to get tail happy in 3.gear... the track is sooo slippy in the wet! was fun but it it quickly dried up.
Gotta have a warm up lap with Miami vice theme- Jan Hammer!
Ouch!!
So just cut that cross-member right out and replace it with a box section, not too hard. Although it will end up as motor out, radiator panel cut off, crossmember off, suspension off and then chassis arms pushed outwards that little bit that they have been pulled in.
Still, when you look at the rally crash videos.....
ahh thanks found the one on ebay but ill se if i can take it out of the parts car :)
anyways cleaned out the barn and gatherd all the shit i had laying arround at one olace, here are some of the engines..
rolla is still going strong! anyone one her got piston rings for a 2T-G i also need rod bearing and ARP rod bolts, everything fits form 2T-C and 3T-C aswell
skid video with 2T-C below..
