GJM85 Posted July 19, 2013 Report Posted July 19, 2013 Fitted these seats today but they obstruct the seat belts. The belt won't retract while its like this. Any ideas on how to get around it? Quote
oldie Posted July 20, 2013 Report Posted July 20, 2013 Adjust your seating position or change the seats again seems the only answer to me! That is of course unless you can change the mounting point to higher up the pillar where there is more clearance. Quote
styler Posted July 20, 2013 Report Posted July 20, 2013 Mount a drop link extension further up on the pillar. Quote
GJM85 Posted July 20, 2013 Author Report Posted July 20, 2013 Mount a drop link extension further up on the pillar. How can I go about this? There are no holes and I'm unsure if its possible to drill and tap higher up on the pillar. Quote
GJM85 Posted July 21, 2013 Author Report Posted July 21, 2013 I rectumfied the issue by moving the seats back 3 inches on the adapter plates I made. I'm 6'1" so I need the leg room. See the paint flaking in that photo? That's why you don't take your car to MSR Customs. They can't even take the time to sand back the door frames before painting. Quote
CREEDY Posted July 25, 2013 Report Posted July 25, 2013 is this the rolla thats usually at langs yatala? if so.....clean as!!!! Quote
GJM85 Posted July 25, 2013 Author Report Posted July 25, 2013 (edited) Yeah bud. She's the one. Courtesy snapshot Edited July 25, 2013 by GJM85 Quote
B.L.Z.BUB Posted July 25, 2013 Report Posted July 25, 2013 (edited) Put spacers under the seat belt side of the seat between the seat and rails so they lean towards the center slightly. Edit: old thread. Edited July 25, 2013 by B.L.Z.BUB Quote
GJM85 Posted July 25, 2013 Author Report Posted July 25, 2013 That not such a bad idea actually. That might give me the clearance to make these seats certifiable. Problem being, although the seat belt retracts while I'm in it. Once I get out they don't and dangle out the door frame. According to what I saw on ACA the other night, that's just down right DANGEROUS! Quote
CREEDY Posted July 27, 2013 Report Posted July 27, 2013 Have you still got the original seats? they looked like they were retrimmed? Quote
GJM85 Posted July 27, 2013 Author Report Posted July 27, 2013 Yeah they've been retrimmed but are pretty shot. The driver seat back rest is starting to bend and they have no support what so ever. Quote
CREEDY Posted July 27, 2013 Report Posted July 27, 2013 well if you wanna get rid of them i'm sure i could put them to use.... Quote
